주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1500 질문 전체 보기
How to reconnect #3 cable on iPhone 3GS
I replaced the front screen on my iPhone 3GS but I am having trouble getting the #3 cable to slot back in under where it came out. #1 and #2 seem to press down onto their connections whereas #3 seems to need to slide under it. Can anyone help?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
가장 유용한 답변
Hello,
The #3 connector has a little black or white tab on the side opposite where you slide in the connector. You need to gently lift this tab, and then slide in the connector. Without this tab lifted, it wont accept the connection. Once the connector is inserted, press the tab down and it will be secure.
Hope this helps,
Xico Solutions
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I did figure that out and got it connected - now the phone will not power up when it is put back together. What most likely did I leave undone?
댓글 달기
If you have it connected and the phone will not power up, it may in fact still be the same connection. If it is loose/not done properly, the screen will not turn on. It's happened to me a million times- take it apart again and retry the #3. Make sure it is in far enough (but not too far).
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
George 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 3,085
