이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 6개:
Is it only during acceleration? Have you tried fuel treatment to clean the system? Could potentially be motor mounts as well. Pop the hood n fire it up. Have someone put it in drive, and reverse. Does the motor look like it moves when you do?
What is the year/make/model? It sounds like a CV joint is going. Do you hear clicks or thunks when making sharp left/right turns? CV joints are known to cause vibrations when accelerating
brandon k 의
I did the fuel treatment for several tanks and nothing has changed. I'll look at engine and check it out. It's a 2017 canyon and this on
Y happens after speeds of 40 and above.
Ed Olson 의
brandon k 의
2017 canyon, no noises at all just vibrates when accelerates. Really notice it in cruse control. On and off.
Ed Olson 의
Definitely sounds like cv joint. Check them to see if the boots are damaged. If they are... time to replace. https://axleaddict.com/auto-repair/Car-V... should help.
brandon k 의
댓글 1개 더보기
