주요 콘텐츠로 건너뛰기
HP Officejet Pro 8620 is a multifunction printer for copy, scan and duplex. This device can be identified by its model number: SNPRC-1401-02
17 질문 전체 보기
Does my unit need a new print head?
Hi all,
My printer is displaying the following message: “There is a problem with the printer or ink system. Turn printer off, then on. If the problem persists, contact HP.” Of course I have tried turning it off and on and doing full power cycles and resets, to no avail.
It’s worth mentioning that there was previously an internal ink leak. The black ink cartridge started leaking and so the printer head was bathed in black ink and it dropped down inside the case and even out of the bottom corner. So that’s what’s caused whatever problem this is, I guess. The ink is now dry and I’ve soaked up as much of it as I can, and removed the leaky cartridge.
Notably if I remove the print head completely, the main menu comes back (and complains about a missing print head, fine). All of the normal functions with, so Wi-Fi, scanning, etc all work as they did before.
Which leads me to the question, is this now a problem with the print head, given that everything seems happier with it removed? If I were to replace the print head with a new one, would that work? I know this isn’t the usual error message for print heads, but maybe it’s broken in a certain way?
Thanks for any advice?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Our repair shop has had I believe 6 of this series of printers, some different external trims but all had the same guts in them. I watched all 6 of them eat their print heads over the course of a year and a half. Have had more come in from clients with the same issue. Every one that we get now including those previous ones go straight to e-waste as we have found the print heads to be so unreliable. You can try another one but from my experience it will likely just fail again after a little while.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Yep, I wasted money on two of these, both siting here with the same printhead issue
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Simon W 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 388
