주요 콘텐츠로 건너뛰기
Repair and disassembly guides for GE Microwave ovens.
349 질문 전체 보기
Microwave stopped working timer works but doesn't heat.
My GE microwave/ convection over wont heat up. If you start it the timer will count down but the turn table won’t move, and the system doesn’t heat up. I have already tried replacing the magnetron, and the HV cap and Diode (per a professionals suggestion) and it still dosen’t work. Any suggestions or just bite the bullet and get a new one? It’s only 6 years old.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @ehodeck1 ,
What is the model number of the microwave?
Have you checked the door interlock switches to make sure that they're all operatingOK?
Usually there are 2 x N.O. (normally open) and 1 x N.C. (normally closed) when the door is open.
They are a safety feature that monitors and connects power to the HV circuit (and possibly the motor circuit - depends on how the motor circuit is wired), so maybe that's why there is no heat. i.e. when a door is opened the microwave is turned off to prevent harmful radiation escaping from the oven.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Hi Jayeff,
I did ohm the switches out and they are working correctly. It is a PEB9159SF1SS. It is a convection / micro combo. Neither is working at the moment. I forgot to mention it had been tripping the breaker randomly for about 6 mos before it quit. Not often but maybe once every 2 weeks or so. My hunch is either the transformer of the PCBA I'm hesitant to buy one as each is rather pricey. Thanks!
@ehodeck1
Here's a link that describes how to test all the functions of a microwave so that hopefully you can determine what the problem is. (scroll to top of page to see all the tests)
The microwave's mini manual part number is GE 31-41074.
Usually these manuals have the schematics which will help to find the problem. I couldn't find a free download online but found this site but you have to join to download it. (scroll down to the download link in the post by Lighthouse)
댓글 달기
귀하의 답변을 추가하세요
Eric Hodecker 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 33
전체 시간: 1,669
