주요 콘텐츠로 건너뛰기
Unibody가 아닌 Core Duo & Core 2 Duo 프로세서
375 질문 전체 보기
질문 마감됨
Display backlighting is uneven and dimming, can I replace?
I've had this MacBook Pro 17" Core 2 Duo for a while now. The left side of the LCD screen is significantly dimmer than the right. Usually after running for an hour the contrast is less noticeable. Is there any way I can replace the backlight? Would I need to replace the whole display?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
I am pretty sure that you have to replace the whole display.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Why would you have to replace the whole display? If the screen is perfectly readable, but is less bright than before, it appears that the problem most likely is a dimming CCFL lamp. Those cost $10. A new LCD is $300. This of course only applies if the screen is behaving properly-- no missing regions, no streaky lines or obvious damage. The real question is are you prepared to disassemble a $2500 computer, including opening a dust-free sealed LCD assembly to get at a $10 flourescent tube and do you have the soldering sklls to properly do the job?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 3
전체 시간: 2,384
