주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
6MB 공유 L3 캐시 2.3GHz, 2.6GHz, 또는 2.7GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.7GHz).
How to remove stuck (stripped/damaged patch/thread) screws?
Hi,
I was trying to replace the speakers of Macbook Pro A1398 following this guide MacBook Pro 15" Retina Display Mid 2012 스피커 교체 and I’m stuck at step 31.
I’m unable to remove one 2.6 mm T5 Torx screw (red) and one 5.8 mm T5 Torx screws (left orange one) due to their screw patch (thread) is damaged.
Is there any possible way to remove them using any tool? Any help would be highly appreciated. Thank you.
Best regards,
Arif
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
You should be able to replace the right speaker as the screws holding it are exposed.
Are you using the proper sized screw driver, is yours worn? I would get a fresh tip/driver to see if that solves the problem. You also need to press down a bit Make sure you open the display so it is hanging over the edge of your work table and have something to pad the keyboard (thin towel or sheet of real chamois leather)
See if a scrap of chamois leather can help in getting a good bite with your driver. I also find a small drop of solvent around the screw head can sometime help and in other cases a soldering iron heating the screw can also help.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
Hi Dan,
Thank you for the tips. I used a new T5 but there’s no grip. May I know where can I find a soldering iron to heat the screw?
Regards,
Arif
@arifk - Something like this should do it Soldering Iron 60w Hakko 503F
@danj, thank you very much. Appreciate it. Let me try out the methods you mentioned.
댓글 달기
답변을 추가하세요
Arif Khan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 6
전체 시간: 281
