주요 콘텐츠로 건너뛰기
Model A1224 / Mid 2007 및 Early 2008 / 2, 2.4, 또는 2.66 GHz Core 2 Duo 프로세서
548 질문 전체 보기
Should I change PSU or ge a new computer?
Dear All,
I own a mid 2007 iMac (7,1 - EMC 2133) that I upgraded to 4 gigs of RAM and SSD two years ago ( running on OS X 10.11.6 since then).
I’ve been using this machine for almost 14 years, mainly for web browsing, office apps, amateur web development and light image processing (creating image composites not exceeding the size of A4 paper).Yesterday, it suddenly died with a flash and a thunder (literally, no power outage otherwise; fortunately I successfully retrieved its ssd - works fine through a SATA to usb3 adapter). I opened it to testify that none of the four LEDs light up (of course nothing happens when pressing power btn). Measured PSU with multimeter: all to 0 V even though receiving 240V.
My question now: should I invest into buying (through ebay) a new PSU? Or should I buy a new computer? [Please consider that I have not ruled out that other systems are ok] What are the chances that another component fails (given the wear)?
Thank in advance!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
I would get a new Power Supply since it's cheaper ($30 at iFixit) and will be easier to repair in the future. I highly doubt you have any other failed components.
iMac Intel 20" 2.0/2.4 GHz EMC 2133 Power Supply 이미지
상품
$29.99
해당 답변은 도움이 되었습니까?
점수 5
댓글 2개:
Thank you very much for your correspondence! However, the PSU is not available in the iFixit EU store (I am based in Greece), so I'll have to purchase through ebay anyway...
Few days ago I received the PSU, installed it and everything's back normal again! Thank you for your suggestion!
댓글 달기
귀하의 답변을 추가하세요
Isopo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 37
