Why are all gears neutral on my Mk4 automatic
The car just one day kinda reved up little high I'm in drive then it just went in to limp mode no serious noises
Update (08/15/2021)
So why is it not going into gears neutral for all
좋은 질문 입니까?
좋은 질문 입니까?
Does it shift? Can you go from park to N, R, or D? Or is it stuck in P? It sounds like you can put it in D and it just doesn't do anything. Make sure it is actually shifting..
From what it sounds like, you need to check your trans fluid. If it is low it will not work right.
If your trans fluid is good, and it is actually shifting out of park and into other gears, then you need to take to a trans shop. This isn't something I'd recommend the average person try to repair. Even i don't work on my transmission. But check the fluid first, and make sure your shift cable and linkages are good, allowing it to shift to other gears
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 7
30일 전: 18
전체 시간: 211
