주요 콘텐츠로 건너뛰기
Repair documentation for the initial Sony PlayStation 5 DualSense controller. Model number: CFI-ZCT1W FCC ID: AK8CFIZCT1
48 질문 전체 보기
PS5 Dualsense Controller - Faulty 3.5mm Headphone Port
I’m running a split Headphone/USB Microphone setup (Audio Technica ATH M50X headphones, RODE NT MINI USB Microphone) and recently my headphone port has begun disconnecting on my Dualsense controller. It happens when I either rotate the jack inside the port, or if I lightly pull on the jack too (a good example of this is shown in this video as to how loose it is: ''https://www.youtube.com/watch?v=gXyNlGFt...). This is a slight annoyance considering I have to then disconnect everything and reset it all up again.
Has anyone dealt with any similar headphone port issues/replacements?
Thank you!
Jasper
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
This has happen in my laptop charger port, the best bet is get a new cable and check the port by a technician.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Unfortunately I've tried multiple sets of headphones with no difference whatsoever and the headphones I'm using work fine in other devices with no issues with connectivity. I'm going to try to return the controller through the retailer I bought it through, however as shown in the video, it seems to be a consistent issue across many controllers. Will keep this post updated with any progression!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I guess the headphone jack is NOT available as a spare part from Sony
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jasper Matthews 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 39
30일 전: 199
전체 시간: 2,925
