주요 콘텐츠로 건너뛰기
Rollei 카메라 및 액세서리 수리 안내서.
4 질문 전체 보기
How to clean the matt screen of a Rolleicord II?
I own an old Rolleicord II. It's matt screen is quite dirty, so I'd like to clean it. Can anyone help me how to do so?
My first approach would be to disassemble the camera until I can remove the matt screen, then clean it with isopropyl and a cotton stick. Is that sound?
Are there any problematic steps when disassembling, I have to be aware of?
Thanks in advance!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Is the inside of the screen dirty? You could take the camera apart though there are some risks to doing that. Firstly, I’d recommend grounding yourself and your work surface so as to be sure you don’t damage the camera with static. iFixit makes a great kit for grounding your workspace and yourself: Portable Anti-Static Mat
For the actual cleaning, isopropyl  should do the job, but be sure to let it fully dry before you reassemble the camera. A screen or optics cleaner could work too
Portable Anti-Static Mat 이미지
상품
$29.95
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I don't think grounding has any effect here, as there are no electronics in this old camera.
댓글 달기
Hello, I suggest you do the cleaning itself not with isopropyl, but with ECLIPSE Optic Cleaning Fluid by Photosol Inc. (you can also use cleaning pads sold by them, recommended). Isopropyl will leave the traces. Clean everything you can with a soft brush, then finish with the fluid. That way, you will have your screen as clean as it was when it left the factory.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks, this cleaning fluid looks good in general.
Not sure thou, if this old matt screen is already coated, i.e., if its necessary to use a special fluid for cleaning?
댓글 달기
For cleaning the matt screen, see the other answers.
Unmounting the matt screen
Simply screw off the following four screws:
Now, the frame holding the matt screen can be pulled out:
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Friedrich Wiemer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 18
전체 시간: 258
