My cruise control only works when it wants
My 2011 Silverado 1500. The cruise control only works when it wants to. I press the cruise button and nothing happens; after a while or another day it works for a while
좋은 질문 입니까?
좋은 질문 입니까?
From what I'm finding, a common fix that has worked for many and is cheap has been to replace the brake lamp switch. Its like $20. If that doesn't do it it might be an issue with the switch/buttons itself and you might have to replace that. Next time it doesn't work try tapping the brakes a bit and trying again. If it starts working then replace the brake switch.
해당 답변은 도움이 되었습니까?
The cruise module is down behind the brake pedal U can replace it Or if it doesn’t work when u press it Just give it a little kick and it will work.
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 4
30일 전: 30
전체 시간: 823
