주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple의 2020년 주력 iPhone은 10월 23일에 6.1" OLED 디스플레이, 듀얼 12MP 카메라 시스템, 그리고 다석 가지 색상으로 출시되었습니다. iPhone 11의 후속 제품입니다.
Yellow spot on LCD
I was about to replace my iPhone 12 LCD with a 2nd hand LCD cause it was broken.
After I heated and was about to remove the face id part of the device of the 2nd hand LCD, I saw the yellow spot.
What could be the problem? It’s already 3 days since I did it and the yellow spot was still there.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi,I saw your quesition.
In this cace maybe 2nd hand LCD broken when it heated.
Yellow spots are often seen at the time broken. I don't know that heating added damage for 2nd hand LCD.
I want to know how to heat LCD,if it's ok with you.
I recommend you to exchange.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Yellow spots are usually caused by way too much heat. They can also be caused by pressure on the back of the screen. You could always open up the phone and make sure there's nothing pressing on the back of the screen in that area. What did you heat the screen with?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Gerenz Mendoza 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 157
