The hinges on MacBook Pro Touch Bar is loosing
The hinges on my MacBook Pro Touch Bar is losing; can we fix that? It can stand at a 90-degree angle but will till down if I adjust it to the back.
좋은 질문 입니까?
좋은 질문 입니까?
Ouch!
I can tell you don’t use your system that much, Apple had a run of defective display assemblies. Basically, the steel hinge pin is press fitted into the softer aluminum and becomes loose overtime (usage). The newer version uses a larger keyed pin so there is less risk of failure.
Apple did offer an extended warranty program for this. I would try to get it covered, you may need to plead a bit asking for a warranty exception as well as this is not your fault!
If that fails its going to cost you!
Here’s the guide to put it in your self saving some money MacBook Pro 13" Touch Bar Late 2016 디스플레이 어셈블리 교체
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 90
