주요 콘텐츠로 건너뛰기
2011년 하반기 모델, A1278 / 2.4 GHz i5 또는 2.8GHz i7 프로세서.
591 질문 전체 보기
airply works but wont screen share tv icon not appearing.
after upgrading to Catalina my mac no longer can screen share. Airplay works thru quicktime & such but the tv icon wont appear on my home screen.
Iv done all the”fixes” in settings in security firewalls display etc and nothing makes the tv icon appear in bar at the top of my computer.
anybody know why & how to fix? I also upgraded to 4.0 bluetooth as well
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
If it worked before with the older macOS, then I think your best solution is to roll back to it.
I would create a bootable USB drive to double check. Down load the older OS from here How to get old versions of macOS.
You are limited to the newer APFS based OS’s unless you completely wipe your drive as Sierra and older uses a different File system (HFS+) and they won’t run on top of APFS based drives.
Technically macOS High Sierra (10.13.6) is the highest version your system can support per Apple. I would recommend creating a bootable High Sierra drive to see if that works if it does then I think that’s your answer.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
David Curran 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 24
