주요 콘텐츠로 건너뛰기
Model A1236 / 4 or 8 GB capacity
134 질문 전체 보기
Why does the click wheel stop working after opening iPod
I opened my iPod nano after my screen broke. I ordered a new lcd and replaced it. iPod turned on, connections connected properly however now the wheel will not allow any move on the listing or even allow to reset the iPod. Its almost as if the wheel was frozen. I'm not sure if I'm missing a step or did I damage somthing. My friend has the same thing with his iPod.
Any suggestions ?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Sorry to say the only thing to do is to reopen it up and go through the replacement instructions again and make sure you have the connector for the wheel on properly and not off center or reversed. Replacing the screen should not cause you any problems like this unless you damaged the wheel cable or plugged it in wrong. You did take care not to cause a static zap of the unit right?
If that doesn't clear it you may look at sending it into a iPod repair place after you get an estimate.
Good luck
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
wesley 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 3,234
