주요 콘텐츠로 건너뛰기
Model A1174과 2 GHz Core Duo 또는 Model A1207과 2.16 또는 2.33 GHz Core 2 Duo
How to do a fresh install of macos Lion?
Hi guys,
i bought recently an imac a1207 that has no os on it, when i boot I’m on the screen of utility with different option (reinstall lion, wipe hard drive,assistance…) i did some research on the internet and i saw that it’s kinda complicated to do an install, so it would be super if someone can help me with a step by step using usb installer. Also, i saw that the update from snow leopard to lion is free, so maybe, i can install snow leopard then lion. Thanks for your help :)
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Do you have another Mac?
@andrewsawesome i have one on El capitan and another on Catalina
댓글 달기
답변 2개
선택된 해법
Ok so i successfully installed lion with a usb. I wrote on a usb the install.dmg onto another usb then i put it in the mac, pressed alt and booted on the usb. Then clicked reinstall lion and it worked !
이 답변이 도움이 되었나요?
점수 0
댓글 달기
가장 유용한 답변
Using your El Capitan based system you’ll need to create a bootable OS installer CD/DVD disk for your A1174/A1207 system. This series if I remember correctly won’t boot from a USB drive. It requires either a bootable CD/DVD or a bootable FireWire drive.
Download the Lion installer directly from Apple from here: Mac OS-X Lion Installer
First run it to install the OS onto the re-writable CD/DVD your system can support so its bootable and then copy over the installer to the CD/DVD following this guide Create a Bootable DVD Copy of OS X Lion Installer. Then use it to boot up your A1174/A1207 system.
References: Apple finally makes OS X Lion and Mountain Lion free to download
이 답변이 도움이 되었나요?
점수 2
댓글 12개:
The installer on Apple website can be launched on el capitan ? Because it didn’t work on the one on Catalina because i tried the other day.
@anthony10006 - Did you follow guide I posted? Create a Bootable DVD Copy of OS X Lion Installer. There is a process you need to follow.
You can't directly launch the installer.
Ok, i’m home this week-end. Also, i didn’t say that if i go in reinstall mac os lion, and i type my apple id, the computer is saying : « this item is temporary unavailable »@danj
@anthony10006 - I have no problem getting to it, the download starts up just fine.
Hello, i searched everywhere but i can’t find a dvd ? :( so is it possible with a usb key ? I downloaded lion and i have installESD.dmg on elcapitan as the tutorial said
댓글 7개 더보기
댓글 달기
답변을 추가하세요
Correia 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 25
전체 시간: 978
