주요 콘텐츠로 건너뛰기
Apple 이외의 컴퓨터 키보드 수리 정보.
242 질문 전체 보기
Logitech type+ keyboard won't turn on
My sister has a Logitech Type+ keyboard for an Ipad. It does not have replaceable batteries, they are rechargeable. The green light comes on when it is fully charged. When the Ipad is placed on the magnet hinge the kbd does not turn on. It should turn the light green, then flashing blue, then solid blue when paired. Nothing lights up. I am assuming there is a problem with the switch mechanism in the magnet but I can’t find any disassembly pictures to see how it works. Any ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I read the instructions closer. When the battery goes that's the end of life for the device.
댓글 달기
답변 2개
가장 유용한 답변
Hi @pwansley
Not sure if this is the same keyboard but here's a video that shows where the two CR2032 coin cell batteries that power the keyboard are located.
Worth checking anyway.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It doesn't sound like the battery, if you are still getting valid charge indication. The enabling action is via the magnet, so I think you're on the right track there. The keyboard will wake when keys are pressed, but I assume you've tried that. Alas, I have no experience with these things.
If it is the battery, I don't think it's ends-of-life. Logitech shows an internal prismatic battery with a cable and connector (not CR2032 as suggested above -- those are for another keyboard). However, they only mention removal for disposal, and do not call out the battery type.
Careful use of a spudger should enable you to open the keyboard, and the battery will likely be labeled with a part number, chemistry, and capacity. You can probably find an exact replacement.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
bill 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 33
전체 시간: 475
