주요 콘텐츠로 건너뛰기
2010년 중반기 모델 A1278 / 2.4 or 2.66 GHz Core 2 Duo 프로세서
794 질문 전체 보기
Need a replacement wifi/bluetooth cable
I recently replaced all the speakers on my laptop as they were broken. While doing this, I accidentally broke the wifi/bluetooth cable. Is there anywhere I can get a replacement cable for my mid 2010 macbook pro? I found one on the ifixit website for the 2011-2012 macbook pros. Is this the same for the 13in mid 2010 macbook pro?
Thanks for the help in advance!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
Can you post a few picks so we can see whats damaged 기존 질문에 이미지 추가하기
Thanks for your reply Dan! I just added a picture of the cable that's damaged.
Update: was able to fix it by properly straightening out the pins and insert it into the connector. The internet and Bluetooth work!!
댓글 달기
답변 1개
가장 유용한 답변
Just in case, here’s the needed cable 13” MacBook Pro, Airport/Bluetooth/iSight Cable, Apple P/N 661-5558. Here
s the guide you’ll need to follow MacBook Pro 13" Unibody Mid 2010 LCD Replacement We don’t have a direct guide for the data cable but is’t pretty straight forward once you open things up.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
ADS 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 74
