주요 콘텐츠로 건너뛰기
The Bose Wave Radio AWR1-1W, also known as the Bose Wave Radio I, was released in 1993. A countertop AM/FM radio system with a high performance stereo tuner and two independent alarms.
39 질문 전체 보기
My Bose Wave Radio makes distorted humming when plugged in
This question was asked already but maybe I have more luck than the previous person. When I plug in the Wave Radio it makes a distored noise. I assume there is a electrical issue. Is it possible to save it from the trash?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
@rahhh can you post an audio file so we can hear what it sounds like? You will most likely have to take it apart, so post some good pictures of your circuit boards etc. That way we can see what you see.
기존 질문에 이미지 추가하기
Failed electrolytic capacitors are a possibility but one cannot rule out bad audio IC's on the amplifier circuitry.
댓글 달기
답변 1개
가장 유용한 답변
Can you open the radio and check for any leaky or bulged capacitors? I have attached a picture below for reference.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
r z 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 23
전체 시간: 672
