주요 콘텐츠로 건너뛰기
Cheap & Cheap Laptop CPU: Intel(R) Celeron(R) N4020 1.10GHz | Maximum: 2.7GHz GPU: Intel UHD Graphics 600 RAM: 4GB Storage: 64GB SSD
3 질문 전체 보기
Laptop USB Port only works at a certain angle
I’ve got a laptop with 2 USB Ports, but one only works at a certain angle. Works fine when pressure is constantly applied, no rotation. Works when tilted down (from upper view). Works when USB is between plugged in & unplugged. Sometimes my mouse lights up, but it doesn’t work.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
I have one that is intermittent also. I think it is the contacts inside the socket. They are a spring hump design. If you are careful, you may be able to lift them using a fine tweezer. They won’t need to come up much. Get the tweezer point just under the hump and lift it slightly. Do all 4.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Be sure to first disconnect the charger and the battery!
댓글 달기
귀하의 답변을 추가하세요
Albert Einstein 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 18
전체 시간: 428
