주요 콘텐츠로 건너뛰기
Officially marketed as Nerf Blasters, Nerf guns are toy weapons made by Hasbro that fire foam darts or, in some cases, foam balls.
How to disassembly Nerf Elite 2.0 Commander RD6?
My son won a Nerf Elite 2.0 Commander RD6 in his birthday, but the trigger does not work. I would like to know how to dissassembly the toy correctly to fix the trigger.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hello, these videos may help to disassemble
  1. https://youtu.be/qO0Tj7WLAaQ
  2. https://youtu.be/K1LHeQBZr7I?t=28
This site is also informative: https://www.reddit.com/r/Nerf/comments/h...
And these videos may help to repair:
  1. https://youtu.be/N8JpePwvuHw
  2. https://youtu.be/KVR_KlwBUuc
I’m assuming you have this model:
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Those last 2 videos are for the disruptor.
yes, though I still find them very helpful, as they are quite similar to your model. :)
댓글 달기
That's awesome that your son won the Nerf Elite 2.0 Commander RD6 for his birthday! It's a bummer that the trigger isn't working, but don't worry, we can fix it. To disassemble the toy correctly, start by locating and removing any visible screws on the blaster using a screwdriver.
Once the screws are out, gently pry apart the sections of the blaster, being careful not to force anything. As you take it apart, remember to keep track of the pieces so you can easily put it back together later.
For more detailed instructions and helpful tips, you can check out https://nerfinfo.com. They have a wealth of information that can guide you through the process step by step.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Nink 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 71
전체 시간: 8,369
