주요 콘텐츠로 건너뛰기
Repair documentation and information for the Google Pixel 4a 5G. Released on October 29th, 2020. Model number: G025E
21 질문 전체 보기
Possible to replace just the rear glass cover/lens over the camera?
I have a crack in just the glass cover/lens sitting on top of the camera of the Pixel 4a 5G. is it possible to just replace this part without disassembling the phone or getting a new phone casing?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
CC, it can be independently replaced, but it’s a part of the back cover. In the 4a 5G, in order to access the back cover, you need to remove the screen, as seen in our guide here.
Once you have the rear cover removed, the flash, mic, and sensor need to be removed. You can see that assembly in this step. The lens cover is then adhered to the back cover.
If you source a replacement cover, you may want to find one with pre-applied adhesive, otherwise water resistance will almost certainly be lost.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
C C 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 233
