주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple의 2020년 주력 iPhone은 10월 23일에 6.1" OLED 디스플레이, 듀얼 12MP 카메라 시스템, 그리고 다석 가지 색상으로 출시되었습니다. iPhone 11의 후속 제품입니다.
iPhone 12 wont charge
has anyone got a same problem like me? unfortunately i dropped my phone but it wasnt too hard but after that my phone cant be charged with the normal charger.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
If wireless charging still works, then it’s most likely a problem with your charging port. Some repair shops will immediately jump to the conclusion that you need a full replacement, but if you look in your charging port with a flashlight, you may be able to see debris inside. The back of the charging port should be the same color as the frame of your phone, unless it’s been previously replaced, and you only need to be careful near the bottom of the port where the pins are located. Besides that, just use a pair of pointed tweezers and remove as much debris as you can, moving from side to side along the back and top of the port. Then you can use a compressed air can to remove anything you’ve loosened. Just repeat until your phone charges. However, if you look in the charging port and see any pins bent, broken, or corroded, you should go ahead and get the port replaced.
Tools for holding and manipulating small and delicate components. Blunt, pointed, and angled versions. 이미지
제품
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Arief Fathan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 19
전체 시간: 366
