주요 콘텐츠로 건너뛰기
The Shark Rotator NV502 vacuum was made in 2013, weighs 15.5 pounds, and includes a lift away handle. The vacuum can be used on both carpet and hardwood floors.
How to replace the lower duct hose on an NV501
I have a replacement hose can’t get the piece off that it connects to to screw it in
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Ouch… few yrs later…
Initiate lift away, lift it away and
Take apart entire head until you have full brush roll access.
Take apart the white mounting part as well.
A few difficult moves coming up once you have wires free.
Be careful with separating clipped tubes from each other. Dont want to break them.
If you fail 3 attempts stop and get some towels/ large rubber anything material to gain grip with one hand, straddle the pieces with legs, pin it down, phone a friend, sos someone special. Once its separated you can GINGERLY cut out the entire thing or just a small section depending on how Old/damaged the tube is.
After that i recommend specialty epoxy since we want this to last for a hot minute or ten. I used jb weld plastics but I also sprayed a plastic protection/flexi-cover all over and inside the tube since it takes so much punishment. Walaa
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Margi Batal 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 18
전체 시간: 187
