주요 콘텐츠로 건너뛰기
Guides for the Wi-Fi version of the iPad mini 5—model A2133. Released in March 2019, the iPad mini 5 is the successor to the iPad mini 4.
11 질문 전체 보기
I need a Permanently remove iCloud Activation lock
Hi,
if it’s ok on here to ask this for a iPad I legally own. I need to find someone who I can pay to do a permanent removal of a iCloud activation lock on a iPad mini 5, ‘Wi-Fi only’ can anyone recommend to me who I should contact to get this done?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 1개
so you own it but its locked with somebody else's applid and password ?
댓글 달기
답변 2개
가장 유용한 답변
Well, it’s easy for technician to remove icloud of IPad that is Wifi Only, by removing the hardware or from the software. You can ask it to technician iPhone that can remove icloud to remove it. But beware of scam, even though it’s easy to know which is a scam or not for those who know the basic process of removing iCloud by a paid tool, or Bypassing iCloud, because usually they scammers don’t even know the proccess of jailbreaking (the most basic of removing iCloud), and so on, but some people still get scammed.
So, the conclusion, yes you can ask the technician to remove iCloud, as long as you are the legally real owner, and can differentiate which is scam or not.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
For this model or any ipad with A12 CPU . Hardware metode is not possible. If you change the SN and WIFI address on these models . You cannot active it . It will stuck on activation(Unable to activate, Error ) because of the new CPU design. It doesn't matter if it is wifi only or cellular.
댓글 달기
I removed iCloud i pad mini 5 help me
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Gary 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 21
30일 전: 65
전체 시간: 1,671
