Top screen is brighter than the bottom screen
When turning the brightness up to 5 it turns off by itself and when I put the 3d slider all the way up it also turns off.
좋은 질문 입니까?
점수
0
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 21
Alexis Lopez in a darkened room when it shuts off, shine a flashlight beam at an angle against the screen. Can you see what should be on the screen?
oldturkey03 의
What do you mean by that?
Alexis Lopez 의
once you turn the brightness upp to 5 it shuts itself off. Once off check by shining a flashlight beam at an angle against the screen. see if you can still make things out. what I am looking for is a bad backlight. With high power they will shut down since they cannot handle that voltage.
oldturkey03 의
I see nothing out of the ordinary
Alexis Lopez 의
how old is the battery? by turning it up you are pulling more power and if the battery capacity has deteriorated than you may need to replace the battery.
stressmaster 의
