주요 콘텐츠로 건너뛰기
The DualShock 2 Analog Controller first appeared with the Playstation 2 and featured only minor cosmetic changes in screw locations etc.
14 질문 전체 보기
Why does the L2 button not work?
The controller had more issues with unresponsive buttons but I put a new membrane on it. Also put a new pin connector as well and all buttons work except the left trigger. Any ideas on how to fix this? I used a 43A membrane and a 18 pin connector.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
The controller is also a model H
댓글 달기
답변 1개
가장 유용한 답변
If everything is lined up properly it might be that the new membrane also has an issue, put it in another controller to confirm whether or not the L2 button works in that one.
I always swap them back and forth from a working controller to confirm which parts are / aren't working.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Jesus Banuelos 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 26
전체 시간: 410
