주요 콘텐츠로 건너뛰기
Released in June of 2009, the 1005HA is identified by its "Seashell" design, and is available in many different varieties in regards to operating system, internal storage, and battery size.
24 질문 전체 보기
Why does my device overheat so often?
Good afternoon, I have a big problem. I have Asus Eee PC 1005HA. And it started to overheat very often. I often have to work at the computer and write a lot of articles, but lately my device began to overheat and shut down very often.
How can I solve this problem? Should I upgrade to a more powerful device, or is there anything else I can do about it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Have you had the laptop for a long time? If so, if you have never taken it apart the entire time you have had it then it might be dirty inside and probably needs new thermal compound on the CPU. That is most likely the problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
brian johnson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 91
