Nasiboo Nasal Aspirator works fine on low but shuts off on max power
Hi
I struggled to find a category but the device works basically exactly the same as a vacuum cleaner. It just sucks air inside to get boogers out of childrenโs noses.
So I can turn on the device and choose the suction strength from low to high (1-5).
Itโs controllled by a turning switch. I can turn it on on 1 and it works like it should. I can change it to 2 and it works too. But after 2 it just shuts off. So between 1-2 it works and between 2-5 it shuts off. If I try to start on a power mode between 2-5 it starts for a second and then shuts off.
To turn on the device you have to press the turning switch. Which goes up and then stays there (if it works properly)
I coulndโt find anything online about the device and I would have to buy tools to repair it so I wanted to hear a couple of opinions if itโs repairable or not.
So my reasoning is that itโs a faulty switch because if it would be a faulty fuse or electronics it woulndโt work at all. Since it starts for a second when I press the button to start it, the power flows and when it goes back up it doesnโt get any electricity so it shuts off.
So I think if itโs only a switch I could buy the tools to unscrew it and to look inside. Do you think itโs repairable? (I also coulndโt find any spare parts for this exact device so I would have to work with whatโs available as generic spare parts)
์ข์ ์ง๋ฌธ ์ ๋๊น?
