주요 콘텐츠로 건너뛰기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
740 질문 전체 보기
usb ports are not working properly if usb pen inserted completely
when inserting mouse or external memory sticks, they are not spotted. If I take it ot just a little, they are spotted and working. the problem is that if I move the laptop, then the connection is lost.
how can I fix it?
Update (11/02/2021)
Coudn’i it be that the pins need just to be pushed a little bit so that the contact between port and jack is more stable?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Are you encountering issues on just one port or both?
to both of them. !
댓글 달기
답변 1개
선택된 답변
Your system only has USB 2.0 (480 MBit/s) by chance are you plugging in a USB 3.0 (4.8 Gbit/s) {also called USB 3.1 just to confuse you!} Cable/device?
One of the issues between 2.0 and 3.0 is a set of extra pins in it connection!
See if a USB 2.0 cable/device works. I’m suspecting the extra pins are shorting out when you push the cable in.
Reference: 5 Fast Ways To Find Different Between The USB 2.0 And USB 3.0
해당 답변은 도움이 되었습니까?
점수 0
댓글 6개:
Thanks Dan. However the problem is happening with an external hard disk that was working perfectly till a few days ago (same thing for a mouse). So I do not think is a USB 2.0 vs a USB 3.0 issue…
@stefanochi - If that's the case your logic board will need repairs as the ports are port of it and the logic within it might be messed up.
@stefanochi - A bent pin which is shorting is what I was thinking at the start but if both ports are having problems that tells me its either a bad cable or something deeper.
Cables are OK because are working properly on other pc's
댓글 1개 더보기
댓글 달기
귀하의 답변을 추가하세요
stefano 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 46
