Are temperature sensors on Mac Pro Late 2013 serviceable?
My MacPro Late 2013 was starting to run a little warmer to the touch than usual, so I ran TechTool Pro 14 which identified one of two temperature sensors to have failed.
Are the individual sensors serviceable and can anyone recommend a parts source?
If the sensors are bundled within a component assembly, would that component be the fan assembly and would the entire fan assembly need to be replaced, and again, would anyone have a recommendation for a source for the fan assembly?
Thank you.
Update (11/05/2021)
Good morning and thank you, Dan. I am located in the USA, to answer your first question.
In response to your first suggestion, I followed both methods that you mentioned. The onboard diagnostics came back reporting no problems, and TG Pro’s paid version also reported no problems. The screen shot is attached below.
I am at loss as to how and why TechTool Pro 14.1, running under MacOS 12.0.1, and my physical touch would point to a problem, but now two other software applications would contradict that. Any guidance and suggestion from anyone would be greatly appreciated.
좋은 질문 입니까?
댓글 1개
Where are you located Country? So we can aim you to a more local source for parts.
Without a firm idea what the sensor is telling you replacing the fan unit may not be the correct part.
Dan 의
