주요 콘텐츠로 건너뛰기
2009년 6월 출시 / 2.66, 2.8, 또는 3.06 GHz Core 2 Duo 프로세서
300 질문 전체 보기
2009 Airport Card with a 2011 display assembly? MBP 2009
Hello, i have a bit of a problem, I have a mid 2009 MacBook Pro 15 inch and i could only find a screen assembly from a 2011 MacBook pro which of course doesnt have an airport card inside with the same isight and sensor cable that the 2009 have,
would it be possible if i bought the 2009 airport card, connected it up with the logic board and left it free inside the case, to hook it up with only two out of the three antenna cables of the 2011 display? since the 2009 airport card only has two antenna connectors but the 2011 has three cables..
Thanks for any insight.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Frankenstein’ing is not really a good idea. The display frames are very different.
Here’s one source for the LCD panel LG LP154WP3-TLA3 15.4" 1440 X 900 Apple Macbook Pro LED Screen
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
oh well, i already got the 2011 lcd which has the same lvds connector so the display it self should work, though airport, isight and etc wont
@Gaming York - If thats the case just swap out the LCD panel its a bit of work but that is the better direction at this point.
yeah thats my plan
@Gaming York - I hope it all works out! Don't forget to score the answer and accept it - Thanks!
just did, sorry it took so long
댓글 달기
귀하의 답변을 추가하세요
Gaming York 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 33
