Why is no fuel getting in the cylinder an not starting
Is there any way any one has a manual for it
좋은 질문입니까?
좋은 질문입니까?
change the gas line and remove the carburetor. use carb cleaner and remove everything to pieces and blow the cleaner in every hole. the float bowl injector is the screw that holds the gas reservoir of the carb to the engine. this is usually the culprit and needs to be cleaned.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 872
댓글 3개
Hello snsjss
Ethan 의
@walker34 your blower a Homelite backpack blower (bp250)? If not we need more info about what engine it has etc.
oldturkey03 의
Plugged gas line, fuel filter, fuel valve or carburetor gummed up.
bill 의
