I need the pads for the bottom
foot pads
좋은 질문 입니까?
The lower case runs about $195 installed by DT&T services. Superglue and replacement rubber like rab777hp suggests is a whole lot easier and cheaper. Plus if you replace the lower case you could zap your board and ruin your whole day.
해당 답변은 도움이 되었습니까?
If you are referring to the rubber feet on the bottom of the bottom case you have to replace the whole lower case, however if they simply came off I suggest reattaching with superglue to your case, as a new lower case is expensive.
해당 답변은 도움이 되었습니까?
You can get them at this link for $14.95
http://www.PowerBookmedic.com/xcart1/pro...
The link will take you to the 12" feet but just click the 15" box, The URL is the same.
해당 답변은 도움이 되었습니까?
You have to buy a tube of super glue too.
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 1,762
