주요 콘텐츠로 건너뛰기
Black stripe on my Sharp Aquos Tv screen
Yesterday I had to remove the back lid of the screen to Unplug the Power cable from the inside. After putting all the pieces back together (screws and lid)I noticed that a black vertical stripe roughly 3cm large has appeared on the right-hand side section of the screen. Today I opened the posterior lid one more time to check whether the connections were fine and they appear to be properly plugged in without any damage. Does anyone have any idea of what the cause could be and if there is a solution to the problem???
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
The screen was impacted, bent, smashed, damaged some how, or a capacitor is going bad, some times they swell up before they blow out, they at times may leak as well, a visual inspection may reveal this condition, it looks damaged by your picture though. if under warranty turn it in or get the extended warranty asap?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
lorenzo sponzilli 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 420
