주요 콘텐츠로 건너뛰기
Repair guides and disassembly information for Apple's 8th generation iPad. Released September 18, 2020. Model numbers: A2270, A2428, A2429, and A2430.
30 질문 전체 보기
Charging only on low wattage charges, and only for a few minutes
This ipad is charging only on low wattage chargers and only for a few minutes before it displays “ipad not charging.” A new battery has already been tried, as well as several resets and updates. I'm not 100% convinced that this is a charhing pirt issue but I dont even know anymore, any suggestions?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Did you even try changing the charging cable?
I feel it's not original cable that you are using to charge your iPad.
댓글 달기
답변 1개
it could be the wall wort or cable is damaged and I hope that is the case. if ot those than the port probably needs to be replaced or you can a bad resistor on the charging circuit.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Garrett Chism 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 57
