주요 콘텐츠로 건너뛰기
MacBook Air 11"의 2014년 4월 업데이트는 새로운 듀얼-코어 i5 및 i7 Haswell 프로세서를 장착하고 배터리 성능을 약간 향상하였습니다.
Usage of a SSD as an external drive
Hi guys,
My MacBook Air is not starting. the battery charges (the MagSafe turns green), but the MacBook doesn’t start… I really don’t know what’s happening. The Apple authorized dealer (repair) told me that is vintage.
Ok, but I would love to recover files or try to solve the problem. It’s a used MacBook Air but it is very well cared. It is a crime to put it in the garbage!
Can I use the SSD (flash storage with PCIe) installed on this MacBook as an external drive? Is it possible to use it as an external drive or try to use it in another MacBook? What should I do?
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
댓글 달기
답변 2개
선택된 해법
there is adapters you should be able to find to at least use it to dump the data.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks! I´ll manage this...
댓글 달기
Here’s the case you’ll need OWC Envoy Pro Portable, Bus-Powered USB 3.0 Storage Enclosure
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you so much! I´ll manage to buy it!
댓글 달기
답변을 추가하세요
MARCUS VITOR 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 4
전체 시간: 126
