주요 콘텐츠로 건너뛰기
A2116 / 2019 / 3.6GHz 쿼드 코어 i3, 3.0GHz 6코어 i5 또는 3.2GHz 6코어 i7 프로세서. 2019년 3월 19일 출시.
What is the part number for the DisplayPort cable.
I need to replace the DisplayPort cable on a 2019 21.5” iMac; A2116.
What is the Apple part number? Who would be a good source for the replacement? Where can I look up Apple Part Numbers?
thanks All!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
I believe what you’re looking for is the eDP cable (Embedded Display Port). The part number for Apple’s actual part is 923-01669. But you will probably find just as much without that searching for eDP cable for your model. It’s also the same cable that’s used in the 21.5” 2017 model so if you find one of those, they are identical.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Um and 1.4 version cable will work
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If you are looking for the external cables you can find them on Apples web site here Apple - Cables Apple sells a few third party cables intermixed with theirs, mostly on the older less asked for cables.
There are alternative local sources which might offer what you need (and cheaper). Also keep in mind the newer Thunderbolt-3 ports on your system also support USB-C cables. Many people find getting a dongle or hub device offers the needed conversion to what your display needs.
If you are looking for an internal cable you'll need to post a picture so we can identify it properly 기존 질문에 이미지 추가하기
Update (11/20/2021)
OK so you need the internal displays data cable 21.5” iMac Embedded Display Port Cable, apple P/N 923-01669
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
John Pizzo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 5
전체 시간: 234
