주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Why are the flex cables shorting out?
I am currently in the progress of repairing a iPhone 6s, I swapped out the lodgic board, battery, home button, and screen. Plugging in the flex cable for the front camera is either draining the battery really fast or makes a quick cloud of smoke. Anyone know why it would be doing this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Cloud of smoke? Definitely no good. Sounds like here are a lot of variables here since you swapped out a lot of components (honestly, that’s nigh on a whole new phone at this point) but here’s what I would check.
  1. Is this the same front camera assembly from the original display that you transplanted? Does the front camera even work despite the other issues? What about the ambient light sensor/proximity sensor? If no, make sure nothing was damaged in the process. Check the cable closely and the cable connector for signs of tearing or damage. If the camera came as a part of the display assembly, my money is on that part is bad. See if you can transplant the one from the original display.
  2. Do you know the new logic board is good? I would check the connector on the board and components around it. See if anything is getting hotter than it should.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Isaac Nakagawa 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 36
