주요 콘텐츠로 건너뛰기
Surface Pro 태블릿의 4세대 버전입니다. 2015년 10월 26일에 출시되었습니다.
20 질문 전체 보기
Can you test it with out the battery?
I replaced the battery but the surface pro will not turn on. If I take the battery out can I test the rest of the surface pro by just plugging it in to see if it will turn on? Or if there is a guide on how to use a multimeter on the board to test it I am willing to try that. Thanks for any help.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
It will run only from your Power Cord, I‘ve tested it. So if it still doesn‘t boot up, there must be some other problem.
이 답변이 도움이 되었나요?
점수 0
댓글 5개:
Thank you for the update. It looks like there are other problems then.
Have a look at the usual problems with this machine as mentioned on this site: https://www.aonemobiles.com.au/2020/03/m...
Hope you will find the problem!
Does the surface pro 4 works without a replacement battery in it, only with the power cord?
My battery has swollen, and it's too expensive to replace it in my country, so i am considering removing the old one and keep using the laptop as a desktop
I am in the same situation @moquedami , did you find out if it is possible? If so, did you try it? Thanks!
@pachi & @nahuel
As I mentioned at the top, it will run without a battery attached.
댓글 달기
답변을 추가하세요
Jake Snyder 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 275
