XR not turning on, power button and the adjacent module get hot
After a screen replacement my phone got dropped and won’t turn on and the area directly around the power button gets hot.
The red is the overheating component. When I have the green connector detached it doesn’t overheat or respond. My computer does not register the phone’s existence unless the battery cable is connected.
좋은 질문 입니까?
댓글 4개
Disconnect all the flex cables except for the two bottom screen flex’s and the charge port and battery. Try booting the phone by inserting lightning cable.
Chris Stables 의
@imicrosoldering which of the cables is the charge port? i'm a little new to working on things this small. Also, is there any way to connect with windows? I don't have a mac and itunes does not want to interact with my phone, though my computer is registering it as connected now
tucker hartman 의
figured out which cable is the charge port, with just the cables you mentioned the same module I have indicated above gets hot and my computer dings but it does not boot
tucker hartman 의
mate i got the same issue how did u
fix it?
Abhiram 의
