주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Backbone One is a mobile game controller for the iPhone. It was released in October, 2020.
Backbone one ribbon cable is damaged. How can I replace it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 3개
Did you ever get this fixed?
This isn't fixable. I've taken the whole device apart and they have effectively glued the ribbon into the central "bone" of the device. You do not have access to that area unless you are willing to break through the plastic, I doubt you will cleanly separate the central bone.
Well, i'm using it for a handheld PC so I wont need the middle part.
댓글 달기
답변 1개
가장 유용한 답변
I had this issue with a JBL Speaker. There was some numbers on the ribbon cable itself so I tried them on the internet and had no luck.
What I ended up doing was counting the number of pins that were on the ribbon cable I then measured it in (mm).
Then for example I went in to google typed ‘6pin 250mm x 20mm ribbon cable' and one poped up so I ordered and it was the correct part and it fit the device perfect and the device powered on. It only cost me like £3 so I didn't mind the risk of ordering it for it to fit or not.
Try this your your device and let me know if it worked for you.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Erik Chavarria 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 79
전체 시간: 3,536
