주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
My Xbox has Heat Problems
Hi,
my xbox has a problem with overheat. When i play on this console it will after 10 minutes overheat and the console turn automatically off. When I restart come the advice that the console overheat Also is the console very loud. My question is how i can fix this problem.
Thanks for fast questions
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Archer,
The first thing I would do is clean the machine. Open the case and dig in to the internals using this guide and blast everything with compressed air. Once you are sure that everything is nice and clean, re-assemble and be sure that where-ever you place your xbox, it has sufficient ventilation (IE it's not in some small cabinet or on carpet). You may also consider some sort of external cooling fan and/or setting the xbox so it's standing with the CD drive vertical to give more cooling surface area.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Thanks for the fast answer but the problem is still there. I Had the console cleaned. I used external Fans. Is there an other solution?
leave the cover off, plug in, turn on, watch the fans.. they might need replacing, or you may need to replace the thermal paste a la RROD repair before you get the RROD.
댓글 달기
답변을 추가하세요
Archer564 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 13
전체 시간: 654
