주요 콘텐츠로 건너뛰기
Released in September 2009, Samsung's GT-E2120 features an embedded FM radio internal antenna along with a Bluetooth wireless connection.
4 질문 전체 보기
Why it is not continue starting
it start for a while the phone models appear and then turn off again..
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 3개
가장 유용한 답변
The model of my phone is GT-E2120 as mentioned here,my phone is not getting switched on,i don't know why. It was initially getting switched off for every five minutes but now it has got switched off completely and I have tried switching it on but it's not getting switched on and i have also tried plugging in the charger but there is no difference,it remains to be switched off.Am not understanding what the problem is,how do i fix this?please help..
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
This sounds like a case of dead battery. Plug your phone into the charger and try to turn it on. Does it? If it does, you need a new battery. If that doesn't work, try doing a hard reset. You will lose all of your saved data, but it may recover the phone.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
it's a common problem. you have to update firmware
http://www.symbianize.com/showthread.php...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
nelson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 12
전체 시간: 3,823
