주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Power/Sleep and Home Button Unresponsive
I have a iPod Touch 4g which has a cracked screen. I replaced it, and still didn't put it back. I attached the two wires from the screen to the iPod, and now the Power Button and touch screen are not working. I plug in my charger, and it goes to the password screen, and I can't slide it.
How can I fix this?
EDIT: The volume button also don't work :/
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
가장 유용한 답변
Assuming that everything worked well before, the #1 culprit for malfunctioning electronics after dis-assembly tends to be dirty or poorly seated connectors. Clean everything well with a high-content rubbing alcohol and make sure the connectors are seated fully. If that all checks out, closely inspect each of the connectors and see if a pin was damaged. Good luck and let us know what you find!
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I tried this, and now the display doesn't light up anymore when I plug the charger in :(
댓글 달기
It is most definitely a damaged on/off, volume flex cable. There is a post elsewhere on this site.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Cytonic 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 1,009
