주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz) 또는 2.5 (Turbo Boost 최대 3.7GHz) GHz 쿼드-코어 Intel Core i7 프로세서.
467 질문 전체 보기
Fixed:MacBook superslow max 10w, 1.0GHZ , battery 0% due thermal paste
Hi, I would like to understand what happens here. In order to lower my MacBook Pro 15” mid 2014 (2gb GPU) cpu, usually 55-65c , 3000rpm (single monitor), 75c 4000rpm (dual 1080p) I decide to change thermal paste. I disconnected the battery cable, not not all pins at once, I pulled it from right to left. No damage on pins. I applied new thermal paste, than the nightmare started. First computer won’t boot. With magsafe pugged in it boots, but clearly slow. At login screen it shows 87% battery (non apple, 83 cycles only ), after logging it shows 0% not charging. Testing cpu scores it gives mediocre 200 single core, 700 multicore . I was before 900, 3800. Using intel power gadget, power never does above 10w, frequency core max 0.8, temp around 55c max. This is the third time I applied the thermal paste, the first using X pattern, it was 42, 44, never above 48c. I have no idea that is going on. I can clearly see performance loss, including video lag, switching workspaces, maximizing. Techtool pro 14 thinks everything is ok. except for battery. Tried to reset pram and smc with battery connected and disconnected. None work. One time computer turned on on battery with fans running crazy, I tested performance was bad but did not check for cpu and power informations. Any advice? Geekbench 5 cpu test does not raise temperature over 59c, nor fan speeds. Takes forever to finish. Previously I had it 3-4k easy on tasks. I see computer running slow even on right click. All happens after change cpu and gpu on my retina.
Tried to max out processor with yes to bit bucket, not help.
Please check my Geekbench full results: https://browser.geekbench.com/v5/cpu/117...
TG Pro Sensors:
Techtool Pro 14 - Passed all sensor tests.
Coconut Battery Info:
I have applied thermal past 5 times. In the 4th I put extra, so here are the pictures before apply the 5th time.
Cleanup and reapply:
Insulator removed, I can see apple thermal paste all over, they are the bigger chunks hardened paste. The one I applied was easy since it still soft just like when I applied. We can notice the Arctic Silver 5 color is a bit darker than original apple thermal paste.
Results after use CPUTune, turboboost enabled just for test. Not recommended since full speed fan tem got to 99c. https://browser.geekbench.com/v5/cpu/118...
Sensor tests - CPUTune on, turbo boost off.
Performance restored after battery replaced. According to my tests. yes apple throttle cpu and gpu performance if Macbook has no battery or poorly functional battery. Not sure how I damage. the battery had around 90 circles and was working before I disconnected sideways from the board.
Testes running on battery only:
https://browser.geekbench.com/v5/cpu/119...
https://browser.geekbench.com/v5/compute...
Passed on all Techtool Pro tests as well.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
If you can lets run the onboard diagnostics. Reboot your system and press the D key to enter. let us know what errors you get.
Reference: Mac startup key combinations
FYI: Apple broke the onboard diagnostics with the newer firmware release so if you are running a newer macOS release diagnostics might not work. Then you'll need to buy this app TG Pro it offers some diagnostics which might be enough to figure things out. Post a snapshot of the main window so we can sell all of the sensors and the diagnostic window at the bottom 기존 질문에 이미지 추가하기
@danj
Hi Dan, thanks for super fast reply. Apple diagnostic does not help at all. Techtool reports everything working. I'm pretty sure it is not, even typing is slow sometimes. It seems like olde days on hackintosh without gpu support, sort of. I updated the question and included images. Appreciate your help. Thank you very much for your effort.
@amafra - There is an anomilly with your battery which needs to be investigated., install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see.
댓글 달기
답변 2개
선택된 답변
Update
I installed new battery, tested performance running on battery only, I didn't touch thermal paste since I don't have proper cleaning spray. Performance on battery is back to normal, boot times everything after replace battery. GPU 1739 OpenCL (Geekbench 5), 907/3631 single/multicore. I will update test on AC after battery drains out and calibrate it.
Seams the problem was the battery Dan. I do not disregard people can have performance problems with termal paste. But again it is not the case here. I appreciate all your help. Remember that I never put too much past, I changed thermal paste many times, the one that picture had much more, was last before full cleanup, and the only one that yes was too much. I pretty sure all times I removed, the proof of that is just replacing battery, removed custom kext and computer is running at correct speeds. You always be correct about battery issues. I can't understand how I damaged it while disconnect since was working. Att
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
Other than checking the battery a bit deeper, I think you’ll need to inspect your thermal paste as leakage of the TIM onto the carrier is about all I can think of here.
Basically, you may have applied too much paste so the squeezed out wetting the small SMD devices causing problems with them.
Take the heat sink off again but before you wipe off the paste take a picture of the chips and the heat sink sides posting them in your question so we can check things out. Also who’s paste did you use?
해당 답변은 도움이 되었습니까?
점수 1
댓글 21개:
I'm going to take picture. That time I might have little leak, first 3 times I did not, I applied it very carefully to prevent leakage. Note, I disconnected battery from the side so I noticed some pins to the left was disconnected last. Other thing, I used 70% alcohol cleaning, meaning 30 water on it. I did not have isopropyl alcohol. It might have some leak bellow black plastic protection around gpu and processor chip.
@amafra - You will likely need to lift the fragile black insulator plate to check under it as I often find the paste will push down under it (both chips).
@danj I should read it before re apply everything for 5th time. I thought to do it but I was worried if it is something I can do.
@amafra - You'll need to lift the black insulators! You had applied way too much paste which is your downfall here. The paste needs to stay on the silicon chip alone you got the insulator covered.
Let's give this a try to see how much is enough TIM, get a piece of TP/face tissue and cut a square the size of the black silicon chip within the insulator (one layer of tissue), now wet your fingers and shape that small piece of tissue into a ball and that is still more than what you need!
So you have a big cleaning exercise here, first after cleaning off all you can physically, we need to now clean the small SMD devices which have been covered (without damaging them!!!)
Here we need to use a pin-point sprayer like this Jounjip Reusable Refillable Multipurpose Aerosol Compressed Air Spray Bottle for Cleaning and Lubrication Using 95% or better isopropyl alcohol to carefully clean each component as the paste will have gotten under and around the component altering it's conductivity.
Once everything is fully clean (no residuals & dry) then we can start again. The amount of paste is just enough to place a small pea in the middle of the chip nothing more! Remember the sized tissue pea we created slightly less.
Once the clean heat sink is pressed against the chip the TIM with flatten out to a very thin layer. The function of the TIM is to fill the microscopic unevenness in the heat sink so you get full transfer of the heat from the silicon chip, its not quantity that matters! Its placement! A little goes a long, long way here.
@danj Thank you very much for all advice, I will look for isopropyl alcohol now and clean everything and come back here. I really appreciate your help. Thank you Dan.
댓글 16개 더보기
댓글 달기
귀하의 답변을 추가하세요
Arthur Mafra 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 15
전체 시간: 406
