주요 콘텐츠로 건너뛰기
Apple의 MacBook Pro 노트북 라인은 전문가 및 파워유저를 위한 제품입니다. MacBook Pro 라인은 MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17" 및 MacBook Pro 17"Unibody를 포함합니다.
20002 질문 전체 보기
Battery with low cycle count displays service recommended warning
I have a MacBook Pro A1989 that was gifted to me. It runs just fine with the power cable plugged in, but will not turn on or run at all on battery. I went to check the battery health and the battery has a low double digit cycle count. The toolbar tells me the battery is at 1% and displays “service recommended”. It also states the battery is not charging.
I’ve tried an SMC reset several times, as well as an NVRAM reset but I still get this message. Do batteries crap out on these things easily? Am I able to physically disconnect the battery to reset this message? Pardon my terminology, I have a passing knowledge of Apple products.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
To get a better idea of the situation, install CoconutBattery (https://www.coconut-flavour.com/coconutb...) and take a screenshot of the main window. 기존 질문에 이미지 추가하기
@andrewsawesome Still trying to figure out this site but hopefully this picture helps https://guide-images.cdn.ifixit.com/igi/...
were you ever able to figure out the problem? I just replaced my mba 11 2013 with a new battery and Service Recommended status is still there (was there on old battery too). reset the smc and doing a full cycle charge on it now.
댓글 달기
답변 1개
가장 유용한 답변
@enron_hubbard
try reseting the smc
https://support.apple.com/en-ca/HT201255
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I've done that several times with no success. At least I think I have. Is there any kind of confirmation that this has been performed correctly?
댓글 달기
귀하의 답변을 추가하세요
Jay Davidovich 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 237
