주요 콘텐츠로 건너뛰기
The HP Envy h8-1534 is a Windows 7 desktop PC. It includes a built-in HP Multi-Display Capable technology that supports two monitors at once so users can multi-task. The HP Envy h8-1534 was released in January 2013.
5 질문 전체 보기
(HP 700-414) All 3 GPU's are failing to post in the same PC
I recently cleaned my pc, and I applied new thermal paste, but after I retorqued the CPU(core i5 4570) heatsink/cooler the pc failed to boot up. I took my CPU out of the socket and I saw 3 bent pins. I was able to fix the bent pins, but now no graphics cards will be detected no matter what I do. Is there a fix for this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi @realroguelive,
What is the motherboard's board number? (printed on motherboard itself).
To find the schematics for the motherboard sometimes it is easier if you know the motherboard's make and model number and you would need the schematics to find out where the problem is
Bent pins could mean a possible short circuit between pins when the CPU was secured and when the power was applied to the motherboard something was damaged. It could be in the motherboard or even the CPU. Worst case it could be in both places.
Straightening the pins afterwards wouldn't help as the damage has already occurred.
Knowing which pins were bent and which way they were bent i.e. what other pins they maybe were shorting out to, would speed up the fault diagnosis as there would be a reference point so to speak where to begin but the schematics would definitely be needed. Here’s the pinout for a LGA 1150 socket (see p.112) that may help with this. I think that your motherboard CPU socket is a LGA 1150 but maybe I’m wrong.
I wouldn't insert another CPU in case there is board damage and it damages the new CPU now as well.
if the schematics can be found it doesn’t mean that it can be fixed. It may be a problem in the CPU socket for instance but you won’t know until you know where the problem is.
If you can’t read schematics you will either have to try a computer repair service who do board level repairs or invest in a new motherboard
Just my take on the problem.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
The motherboard is a Pegasus Memphis-B and Thanks so much!
@realroguelive
Unfortunately I can't find the schematics for the board.
As best as I can determine it is a Pegatron IPM87-MP board used by HP and known as a Pegasus Memphis-B.
Pegatron is the actual board maker.
That's okay. I looked at the pin out and I got some pins on the top right. It still powers on, but no GPU detected. I'm probably going to take it to a repair shop and get an estimate.
댓글 달기
귀하의 답변을 추가하세요
Drew Stroud 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 208
