주요 콘텐츠로 건너뛰기
Repair and modification information for the Creality CR-10S Pro, a 3D printer from the CR-10 series released in 2019. This first version was succeeded by the CR-10S Pro V2.
7 질문 전체 보기
I need help in replacing my nozzle and bowden tube in printer
I am looking for someone to help tweek my 3d printer. I recently had to change a nozzle from a clog and it is not printing as good as before the clog. I live in RI. I can bring my printer to them ot they can come to my house.Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
where are you at im in colorado
댓글 달기
답변 1개
Hello! so to replace the bowden tube and nozzle, you want to heat up the nozzle to around 170C. then use the small wrench in your creality kit to unscrew the nozzle (youll need to unscrew it clockwise i think)
to remove the bowden tube, you'll need to
first remove the blue clips from the tube (from the extruder side and the hotend side)
push down in the white plastic nut/part till you hear a soft click
pull the tube you
another way is to use the large wrench to unscrew the big nut on either side of the tube
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
booboo759 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 42
