주요 콘텐츠로 건너뛰기
Apple의 7세대 iPad 수리 안내서 및 분해 정보.
Ipad unresponsive after screen replacement.
I repaired my Ipad 7th generation about 6 months ago and in the process accidentally broke my LCD panel. I recently purchased a new LCD panel and installed it into the iPad however the iPad is now completely unresponsive and will not show as connected when I plug into a computer. it is possible I forgot to isolate the battery on the original repair so I am not sure what to do about this. thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Well there could be a number of issues that could have caused this I will help try to narrow it down for you.
Issue 1
Potentially if you have left the battery connected while performing the repair then you could have made a component blow. In this case micro-soldering would be the best way of fixing.
Issue 2
While you were performing the LCD replacement when you lifted up your connectors you could have accidentally damaged some of the components by prying on them with out realising some of these parts can be so small you can't really see them by eye this mistake is very common.
Issue 3
The LCD you are using could be the issue there maybe something wrong with it from the supplier. If you have a new LCD handy test it with that before hassling your supplier.
If you have a digital usb voltage meter connect your phone to it and read the display if your getting a very high reading then chances are you have a short circuit inside this can help you guesstimate the issue without even opening the device.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Angus Ison 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 9
전체 시간: 311
